how to design a centrifugal pump in Pro E ?
what are the procedures to deign a centrifugal pump in Pro E ? what are the parameters required to design a centrifugal pump?
if you really want to design you need sections of volute!!!!
parameter is :: the section should be such that thickness continously goes on increase from the starting of the curve...
and if you just want to make it for just showing....simply use spinal bend :)
