How to design a kinova robot in solid works
Pls help never worked in solid works before
You can use this model as an example and work on the other parts of the robot. It is a daunting task but definitely doable.
Humanoid Robot arm and elbow
Good luck and share you work with us when done. ;)
P.S.: By design, I take it as you mean modelling it.
thank you sir
will share my work once it is done
