How to design cam for 4 cylinder radial engine???
I am creating new radial engine i m completed cylinder, piston, connecting rod, cage design but how timing is possible?
use machine design equations to get cam profile. then use splines to draw the sketch and extrude to make it 3d.
I think you'll need an odd number of cylinders for a radial engine.
