how to design conventional leaf spring?
I want to design leaf spring on catia with all parts such as u bolts,clamps with dimensions.if I can get the 2d drawing I can myself do the design on catia.
pls if can the exact the dimension of leaf springs with its parts it will be better for my project.
if you want to design it with surface module use sweep module ,or if u want in part module use rib .. use assembly for better result
