how to design cross cut shaft in solid works for shrdder
i want to make a cross cut shaft for shredder pleases help me through out pic of slimier file is attached please check it out
1 - 2 Extrude a shaft of the correct diameter and length
3 - 4 Create a sketch to represent the missing material, and do a cut revolve
5 pattern the cut along the length of the shaft
7 Sketch a circle on one end, use the Curve tool to create a helix with the correct direction and rotation
8 Sketch a shape to represent the missing material
9 Cut - sweep the step 8 sketch along the step 7 helix
10 Do a circular pattern of the cut sweep
11 Add additional details as needed.
SolidWorks model is in 2016
Comments 2
