how to design drill bit?
i have manage to to draw half of a shape of of the drill any one can help me to finish the rest of it i have put a circle and an arrow for the bit iam needing ?
You can create a work plane as far as you need from the face you desire the extruded portion on. After doing so repeat this process on the other side. The easiest way I would say to create the portion between the two extruded portion is for you to do a loft.
