How to determine the size of a support rib?
In the pic you see simple "L" structure, I need to support it with the rib as shown to prevent tilt. I do know it is a matter of counterweight but how can you simulate/determine the size/angle of the rib ?
You must use 45deg. angle and use the width for the rib as 75% of "L" structure width it will be safe your support
