how to divide table in catia?
hi guys,
i have problem with catia hole table. how can i remove some line in my table like attachment
My picture is from Solidworks, but many of the table functions work the same so I'll give it a try.
For tables calling out dimensions, holes, etc. you can usually select all of the cells that you want to merge, right click, and hit merge cells.
If you are trying to group uncommon cells it may not give you this option.
There is also a setting when making the table that will allow you to combine any likewise cells.
thanks Mashi for your suggestions. it works according to the catia process it's same we have merge commadns in catia.
