Missing feed
how to do an assembly in gusion 360?
By Vinayak Nidagalkar on 22 Feb 14:02 1 answer 243 views 0 comments
what is the best method to perform an assembly in fusion 360?
1 answer
  • Mayara Gualberto
    Mayara Gualberto about 2 months ago
    You can use the tool "joint" (J). Select the faces you want to align and after type "J". After this, will show a new window, select the correct constrant and click in "ok".
Add your answer to: "how to do an assembly in gusion 360?"
