how to do coil spring animation CATIA V5 DMU kinematics?
how to do a typical coil spring mechanism using DMU Kinematics in CATIA V5
Hi,
Spring mechanisms can not be simulated in Catia V5.
As it comes under dynamics, Catia does not have any inbuilt capability for that ,but can be done by integrating with some other softwares.
If you are looking into simulating the spring while being compress or being pull CATIA are able to do that IF you have SIMULIA ANL(Non Linear Analysis)
Because spring in a non linear behaviour, ANL can simulate the spring being compress/pull by a certain force.
