Missing feed
how to do pattern in sketcher mode in pro e
By satish on 09 Mar 04:45 6 answers 0 comments
while creating a part i want to use pattern in pro sketcher mode it is possible or not
  • jure
    jure over 4 years ago
    Answer is quite simple... you can't
    ProE is manly focus to use pattern of the features rather than pattern inside sketch.
    Walk aroud is simple Ctrl+C, Ctrl+V of the features.
  • rakesh
    rakesh over 4 years ago
    You can't use Pattern commend in sketcher, but you can surely use mirror command (by drawing construction center line) to do pattern.
    Its all up to your creativity & imagination to get pattern...
  • krunal
    krunal over 4 years ago
    if u r work in part module that time u make a sketcher pattern in sketcher mode..1st make a sketch and after select pattern u done a pattern..
  • jehan kothari
    jehan kothari over 3 years ago
    use geometry pattern :)but u need to come out of sketcher mode...then you can patter your sketch easily
Add your answer to: "how to do pattern in sketcher mode in pro e"
