How to do simulation of spring in catia?
Compression and expansion of suspension system?
If you are looking how to animate a spring, I made an tutorial. It is a little bit fake, but I don´t think that a "real" animation is possible.
greetings
@hailstone--let me see that tutorial pls upload that!!
The easiest way is:
- divide the spring in two parts (half length)
- twist these halfs into each other to change the length
Hello PAWAN!
Here is the link http://www.youtube.com/watch?v=XCpmU14xwAM
But I will remove it soon, and replace by something different. Remember it is more a FAKE n ot a real simulation.
greetings
I tried separating the spring into two parts and then simulating... but i got some problem.. i wud luk into it and if i get successful i'll post a tutorial 4 u. :)
Twisting the two springs in the Kinematic Workbench is only a fake. But AFAIK the simplest method:
- create a cylindrical joint between the axes of the two springs
- crate a point-curve joint between the springs
The upper spring is turning to change the hight.
got it on solid works but still trying to figure out on catia!!
Hello pawan... I've a good news for you.
Have a look at the tutorial I made myself.
Tutorial: How to make an animation for a compression spring in Catia V5
