"how to do structural and thermal analysis of disc brake rotor using ansys software
coupled field analysis of disk brake rotor using ansys software
On Youtube you can found the similar study, in which the principle is manner to generate heat based on friction.
How to do it using heat flux as a input parameter instead of temperature
it is not useful the file you are entered not opening and give the details about ansys versions
