How to do the edge fillet in Knuckle joint in CATIA
I got stuck in the final stage of part design of Knuckle joint where you use the fillet to make a curved edge between the octagon and the square. How to do it in CATIA
if you can't use command fillet, i think you should use command pocket with circle
