How to do the edge fillet in Knuckle joint in CATIA
I got stuck in the final stage of part design of Knuckle joint where you use the fillet to make a curved edge between the octagon and the square. How to do it in CATIA
Go to the option insert ------->dress up features-------> you can choose the fillet you want
This is how it came out when I used the edge fillet
Might be a mistake in the part design once go through that and tell me back kaviya
Not a 'fillet' but a chamfer, with a generous tool lead-in radius. A good design will follow the manufacturing method IMO.
This is simply a swept cut as shown in the attached; the chamfer width & angle defined in one sketch, the swept path defined in another.
use revolve and remove the material... best and easy way, you may use surface commands it'll make modeling easy...
This is what happens while i do the edge fillet
Try this,
it works
Knucklejoint
Go through this, you may find it helpfull
Just follow simple steps below,
