how to do the modification of my Catia tools of making axes correctly ??
when i sketch the axes in catia as a first step the constraint of verticals and horizontal have not shown in green also as correct .
what should i do?
you will see the difference in my photos .
You have to switch geometrical and dimensional constrains on. Take a look at the picture.
the latter picture shows that you use the command "Axis" to draw the vertical and horizontal lines , in this way , the axis is a construction element and is always dashed , and it will be taken as a profile element for further operation
