How to draw a circular route
Attached is a picture to make my question easier to understand.
I'm trying to draw a circular plate (the shape is represented by the red circle)
And then within the plate are 6 holes.
Every hole is supposed to have some liquid flow through it to an exit, and there are channels that will bring the liquid. (I put 3 in the picture -lines yellow, green and purple)
All the channels share the same exit.
How do I draw 6 separate channels in the plate?
I tried using the Helix-Spiral tool, but the tool doesnt allow me to pick the path of the channel I'd like to.
A sketch for now will be good. Thank you.
