How to draw a variable helix pitch and radius in siemens nx?
Helix Drawing
To get a variable pitch and radius you will need to use the Insert>Curve>Law Curve function and use mathematical equations to define the radius along with any of several laws to define the pitch. Attached is a file containing two examples, one of which uses a built in cubic law for the pitch and one that controls the pitch through a law curve sketch.
use the law command in helix curve option..u can make variable radius helix curve by law command.
please help me 3d model with nx với file đính kèm bên dưới
thanks
