How to draw Center hole 90 degree according to the DIN 332 in Drafting of Catia?
How to draw Center hole 90 degree according to the DIN 332 in Drafting of Catia??
These Type Center holes configuration created Manually and saved .txt format in below location, C:\Program Files\Dassault Systemes\B20\win_b64\reffiles\standard
As per CATIA default above said location already made two standard file, one Metric thick and another one is Metric thin, You just add one moreText file and add manualy everything. That file conifguration you added in Hole option---> Threaded---> Add----> Click your file. Then DIN 332 configuration made in Hole option. Just Try, in future i will tell
