how to draw holes in pcd with chord method
i have problem in draw a holes in pcd they given radius of pcd with some angle and chord spaces length
hi will you able to send detailed specification?
You Can use ARRAY command , if u have angle available
Example: for PCD
by using "HELIIX" we can give pitch circle diameter
for pcd in helix choose the turn Height
