How to Draw Welding Detail in solidworks?
I want to know that how can we draw detail drawing of welding detail like in boiler or pressure vessel in solid works?
If you want to represent welding detail in a model, you can use a multi-bodied part and make SolidWorks think it's a Weldment (Weldment button bar, Weldment). Then use a weld bead. Alternatively, you could combine the bodies together and use fillets.
Hinge, Heavy duty, with Drawings
I want like this welding detail in Assembly mode, so i can directly make drawing from that. I attached file. if anyone know, kindly help me.
