How to edit a block with visibility of main drawing in AUTOCAD???
Using process of block editor in place.
Do it as per downward ...
And HIT the button IT WORKED.....if u see it worked properly......
Answered with a tutorial: https://grabcad.com/tutorials/how-to-edit-a-block-with-visibility-of-main-drawing-in-autocad
command :"refedit"
then select the block for close
command "refclose"
