How to edit geometry of the assembly drawing in Pro Engineer or Ansys Work bench or Solid works?
I have already been provided with the assembly drawing and I want to change some of its dimensions, the files are in Catia format. I have Solid works software and I can also use Pro Engineer for the edition.
I am also attaching the file in Step format
I'd remake the two files in SolidWorks, and then make changes to the sketch dimensions.
Both parts look like simple revolved profiles (sphere and cylinder with a curved face.
Syed,
What are the dimensions you need the new files to be?
What version of SolidWorks are you using?
I've attached the current dimensions (in inches)
