How to enable other balloon frames in CATIA Drafting?
Currently in CATIA Drafting I only can use just the circle type for balloon frame. I can see other types of frames but unable to select it(dim color). Is there any method to enable the other types of balloon frames.
The types of balloons available are laid down in standards.
Under Tools > Standards, you may be able to choose which standards file you can use (or your employer may have restricted access to standards for non-administrator users). Select Drafting rom the Category drop-down box, and choose a different one.
If you are familiar with xml files, you may even create your own standards file ;)
Comments 2
