How to export from .step or .iges or .stl or .ipt to .obj or .c4d ?
Do u know any way how can i export it ? or do u know some good freeware program which can do it ? thank u
It's not exactly what you mean but you do a lot in the .WRL file
http://www.micromouse.ca/
and it is almost free (trial is free)
regards
If you really want to be converting between file types, try MeshLab. I believe it's free, and it can convert many different types of files to other types. Great for inter-CAD conversion.
On OS-X at least, read STEP/STP in to the free (open source) CAD Assistant (https://www.opencascade.com/content/cad-assistant) and use the floppy disk icon on left to save as ply (w/ colors) or obj (w/ mtl). Also check out the cool "Clipping plane" feature (bottom icon on left).
If you want to colorize first, use FreeCAD and http://sliptonic.com/freecad-hidden-gems-setting-colors-for-individual-faces/, save as STEP w/ color and follow instructions above.
All free & open source.
