how to extrude at angle in autocad
what command is used to make extrude at angle .....i want to make below model .
You can rotate the plane that you want to extrude at the desired angle before applying extrusion.
Good Luck :)
you could also just sweep it using a polyline.with the desired angle for the surface to follow
Like us on Facebook:
@https://www.facebook.com/metapexofficial/
Subscribe to my channel: @https://youtube.com/riopaildelan
