Missing feed
How to get an oval gear on a 3D printer
By Roger Vilder on 19 Mar 09:03 1 answer 0 comments
I need to produce an oval gear of about 7 to 8 centimeter on the long side, 4 mm thick, with a hub of 15cm diameter for a 5.9mm shaft.
Thank you for answering
Roger Vilder
1 answer
  • Roger Vilder
    Roger Vilder over 2 years ago
    "How to get an oval gear on a 3D printer"
Add your answer to: "How to get an oval gear on a 3D printer"
