how to get dxf files in one sheet from soldeworks assembly?
solideworks
It sounds like you need to create a drawing of the assembly.
Once that is done you can export/save the drawing file as a dxf.
For a single sheet, you'll need to make sure the drawing is created as a single sheet.
