Missing feed
How to import dxf files in solid works and how it will extruded..
By Chetan Ambekar on 17 Aug 09:35 1 answer 184 views 0 comments
Actually i can import but not getting extruded part
1 answer
  • Robert H.
    Robert H. about 1 year ago
    If it is a 2d DXF, like most of them are, you will have to use the imported dxf as the basis for a sketch or sketches to generate your own extrudes and whatnot.
Add your answer to: "How to import dxf files in solid works and how it will extruded.."
