How to increase the size of arrows in Drafting without Administrator?
When i given the dimensions and print out the drawing their is not clearly shows arrows in whole drawing. when i go to properties their only for line thickness option not the arrows. Is there any option or Setting for increase the size of arrows in drafting.
The only way to change the arrowhead size of CATIA dimensions is to change the drafting standards, and that requires Admin privileges.
(unless the dimension arrowheads are very small; make sure you are working with the correct units)
you can change the arrow head and tail long from properties.
Just made a quick search for arrows and change them. Also you can change the line thickness for print out with the same way.
if you dont want to make this manually you have to go with administrator.
