How to insert dimension(x,y)in B.O.M table automaticaly
I want to know, if it is possible that dimensions of same thickness rectangle parts (same as attached file) in an assembly, is added in B.O.M table automatically. A sample file is attached.
Hi, of course you can. You must add custom properties to the model, and then add a column to the table BOM.
I have a question, why don't you use to this model weldments? It's will be easy.
Best regards,
