How to install Siemens PLM server for NX 9.0
I installed NX 9.0 long ago and everything was just fine. But I didn't open the software for a long time until now and the software was not working, so i uninstalled it. While installing it again, when i install the Siemens PLM server, the following error shows up even though i 'run as administrator'
on you tube you get the installation video
Hi
Have you fixed your problem? I have the same one. If you could manage to install the license server can you please give me some information how you did it?
Try un-installing both NX and its License Server module. Use a good application removal tool to clear out any registries from the faulty install and then start by installing the license server followed by NX. It should work.
I got this error message, tried updating Java with no success, anyone has knowledge on how to fix this?
