how to know a sketch continuity in nx as like sketch analysis in catia
when i go for extrude command , it says that the sketch in inconsistent. the reason behind this is open sketch. so how to find the open ends in a sketch in nx
the sketch will be in closed loop after exist the finish sketch it indicates star mark on the edge of open loop and back to the sketch and correct it
I'm looking for the same solution. Did you find anything that could work?
