How to let Sketchup STL save more surfaces?
Import job always missed surfaces, tiny ones. What should I do? And if any software or plugin could fix those holes, that would be great...
Hi Alex, Sketchup doesn't do well with "tiny holes" I have this issue alot the only work around that sometimes works for me is to change the scale so im importing it 10x bigger then once it has imported scale back down. or you can try http://www.meshmixer.com/ which has some very simple tools for fixing holes in models.
