Missing feed
HOW TO MAKE A DRAWING OF THE SHAFT SHOWING THE MOUNTING OF THE BEARINGAND THE DESIGN OF THE HUB.
By rashid on 31 Jul 21:11 1 answer 1011 views 0 comments
THE ONLY IMPORTANT DETAIL REQUIRED OF THE HUB IS MOUNTED TO THE AXLE
1 answer
  • a1ce339a
    a1ce339a about 4 years ago
    i THINK YOU NEED TO LEARN THE PROGRAM FIRST. AND 2ND YOU REALLY CANT UNDESTAND WHAT IT IS YOU WANT.
    What Shaft?
    What bearing?
    What Hub?
Add your answer to: "HOW TO MAKE A DRAWING OF THE SHAFT SHOWING THE MOUNTING OF THE BEARINGAND THE DESIGN OF THE HUB."
