how to make a gear transmitter of torque i/p 1Nm and o/p 80Nm (GR = 80) OF DIA 35mm
hi.. the main problem of this being low area and high gear ratio (80 Nm, max pitch circle diameter being 30 to 35 mm )i have tried designing it of hypocycloidal type (huge interference problem) and cycloidal gear transmitters.. can some one suggest a better design please.. i am using solid works for the modelling part
