How to make a mate between a set of weights and a pulley ?!
I'm making a gym machine for a college subject and i cannot make the weights lift
My problem is I can't mate the pulleys with the weights , can you help me please ?
I have 3 days to deliver this :s
Not very simple to answer.
Need to know the exact shape of the two identities you want to mate, bit I think it needs to be a concentric mate. If this doesnt work you can always make a "ghost" entity. Two shapes that you CAN mate, and than hide those shapes.
Hope you'll succeed.....
the machine has 5 pulleys but for now i'm trying to make it work with just two.
i made a gear mate between the pulleys but now i can't find a way to made the weight ( which is just a rectangular block ) to follow to rotation ...
Maybe I could draw a line , representing the imaginart cable as the path the weight should follow , but still how will the weight lift ?
Sorry mate, i wish i could help but i do not know.
My only suggestion to you is "just try" or use the help function.
This will sometimes work.
Suc6
I'm completely blocked ... i've tried every type of mate ... i'm missing something :s
