How to make a parametrical seams with Catia V5 ??
Hello anyone knows how to make a parametrical seams with Catia v5 or V6 , I want to learn as the attached picture, Thanks
Thank you, thank you ,thank you, I will try it, no doubts I will need your help for sure, thanks again mate.
Hi, you can check my tutorial on parametric design in CATIA v5. you can do same steps as I did because they are basically the same problem.
