how to make a pipe of any diameter by using plate ? And how we can cut a plate to make a bend pipe of an angle of 90degree?
ipe of any diameter by using plate & how we can cut a plate to make a bend pipe ?
You can use sheetmetal design>create
- Bend>Roll. /To create pipe from plate.
- Cut to define need andle on one face
-Assemble pipes /to get final look as in the attached image.
