How to make dome go through other objects
need a lofted boss/base to come out of dome but it doesn't make dome over all of object
makes it between edge of object and lofted boss/base
Comments 2
HaHa, okay ...
Use the Rollback bar to go before creating the dome, make your lofted body without checking the Merge Result option, make your dome then use the Combine feature ...
Another way, make a plane coincident with the face the dome will be created on, make your dome then use the plane for your sketch instead of the long gone face ...
