How to make double cardan joint spin around itself Stefanos Stamoulis 12 Sep, 2015 01:12 PM Hello,im working on a steering system with double cardan joint. The one end spins correctly but on the other end with steering wheel is turning freely around the the center of the cardan,instead of the 2nd ends axis. 1 Answer Rosa Answered on 27 Jun, 2016 07:46 PM Use pin constraints on all axes and set up scope of angle movements
