How to make FEA analysis in Ball Valves?
I designed a ball valve according to ASME and API standard. I calculated the wall thickness using formula. Now I want to check the wall thickness is under the specified pressure range or else. How to make FEA analysis in solid works or any other software's. I'm eagerly waiting for your answers. Thanks in advance.
Do you have SolidWorks Simulation or SolidWorks Flow Simulation?
