How to make fluid and gas flow simulations.
I want to make some animations such as a hvac system designed in CAD software and this system is animated with camera movements and gas will flow through the tubes, liquids will flow thruough te pipes. And of course the whole animation must be rendered. I wait your advises.
What software do you use? Solidworks has flow simulation as part of its basic software package and is fairly easy to use. There are several tutorial videos of it on you tube.
