how to make pipe in assembly?
I want to know how pipe is made in the assembly .please answer
I have a assembly with part A and part B. How can you create a new tube (routing) from part A to part B while in the assembly
Define the cordinate point in the assembly by giving x y and z values of points.
then by pipe command thru these point create pipe easily. You can change the pipe path by adjust or edit the values of x, y , z values of each points.
i hope this is sufficient to make pipe in assembly.
