how to make solve as menu visable ?
By mohamed hassan on 28 Nov 21:58 1 answer 156 views 1 comment
i cannot this spring flexible
Added images
Square
1 answer
  • Jonathan DeRoner
    Jonathan DeRoner 10 months ago
    Is the spring you are showing part file, or jest a simulation representation? In inventor I know there is know way to show a spring compressing except for the visual of the joint itself. You may be running into the same case in solidworks.
Add your answer to: "how to make solve as menu visable ?"
