How to make some cone shapes
I have a little question about how we can make some design in Solidworks.
I put some images of what i would like to do.
On the soaddish we see every hole has a conic shape
On the Gopro case there is also a conis shape at the lens
thanks for your help
Best regards
I would use the loft command with some guide curves.
You can specify taper angles on the Extruded Boss/Base and Extruded Cut features. Add a Fillet to finish.
