pedro ryan decina jr
how to make sub assembly of a assembly fexible to the main assembly
Question by pedro ryan decina jr
Sir/Mam,
Iam ryan from Philippines. iam having project but iam stock in this issue.
i have a hydraulic cylinder as an sub assy. of a mast as my assembly. I make my h.cylinder(sub assy) flexible to my assembly and it works.. but now when i attached my mast(assembly) to the main assembly, the h.cylinder(sub assembly) in not flexible... is there a way i can still make the h.cylinder(sub assy) flexible to the main assy??
I attached my diagram here for a reference.
hope you can help me in this.. ^_^
Stephen Nyberg
Answered on 14 Feb, 2015 04:48 PM
In your main assembly open the properties of the sub assembly and make it flexible. Look here on how to do that;
https://grabcad.com/questions/tips-on-creating-path-mates
Ryan
Answered on 18 Feb, 2015 09:43 PM
In your assembly (mast) design tree on the left side of your screen, right-click on the subassembly (h.cylinder). To make (h.cylinder) flexible select the button in this menu titles "Make Subassembly Flexible". It has a yellow T shaped part and a green box.
The second way to do this is as Stephen said from within the properties, which you can access in the same way, by right clicking the subassembly (h.cylinder).
