HOW TO MERGE THE SURFACES IN THE SOLID BODY
I HAVE A BLADE WITH SO MANY SMALL SURFACES.I WANT TO MERGE THEM ALL TO GET CLEAR ONE OR TWO SURFACES.HOW IT CAN BE DONE PLEASE HELP ME
Comments 2
Why don't you try rebuilding the part? By that I mean you stay in the same file and recreate the part over the part you already made. I'm doing my best with the information you gave me.
This model has lost the 'resolution' of the original model and was probably generated from an .stl or similar output of the original model, as evidenced by the mesh triangles.
I'm not sure it's possible to get the original smooth surfaces exactly from that. Maybe somebody has an easy solution however.
You could fake it pretty good by recreating some sections and creating your own lofts.
Comments 3
USE "INTERSECT" FEATURE
and select the surfaces you want to merge..
