How to mirror in draft mode in Catia?
When creating a draft of a modelled part, is there a way to do a mirror or symmetry of the draft, without have to first mirror the model. Typically we model only the left hand unit, but would prefer drawings of both LH and RH parts for machining purposes.
if you want to make this associative (linked), as far as i know there is no way. but if you want without associative there is something. first take the views and make one active. create symmetry line. then select view boundary with rectangular trap and use symmetry command in drafting. you can use this method for both 2D and isometric views.
