How to model a parametric gas turbine or steam turbine blades in solid works ??
How to import coordinate points ,
How to fix them at correct place ,
How to add radius near hub and airfoil,
do you have a specific design? or everything open?
Iam having a 2D drawing with coordinates .. of the design
all of your requests are implementable in solidworks. to give a more specific direction, I Need to see the 2D drawings..
Sure sahedul below you can find the attachment , And if you want i can send the Cad model too, i just want to know procedure of making a turbine blade :)
